2000 RR engine noise??? - Land Rover Forums - Land Rover Enthusiast Forum
Old 10-11-2009, 10:18 PM
Rhino1's Avatar
Member
Default 2000 RR engine noise???
Okay, so i know it's getting cold in the Idaho area, my RR is having problems it seems. As i accelerate from a stopped position, for the first 2 gears it seems, there is a whine from the engine area. kinda like a wolf howling. Does anyone or has anyone heard this or had a prob with it? I would appreciate your feedback on this. It goes out after about 5 seconds. but it does it anytime i have to accelerate, or step on the gas.
Old 10-11-2009, 11:51 PM
handsome rob's Avatar
Senior Member
It is so hard to say, maileage of the vehicle would help as well.
It may be the belt slipping and then as it warms up it grabs.
Does it only do it in drive or does it do it when you rev the engine when in park? Could be the oil in the transfer case that is cold who knows, I think you need to investigate the source a little more so we can help.
Old 10-12-2009, 01:02 AM
LRScott's Avatar
Senior Member
LOL NAMPA!!!! I'm in Meridian! I would think it is your differential that is howling, it is a fairly common problem/occurrence.
Old 10-12-2009, 11:17 AM
Senior Member
Cool, more Idaho guys.
Would the diff stop making noise right away? I have never had one go but I would have thought it would keep making noise as you kept driving it.
Old 10-12-2009, 02:45 PM
LRScott's Avatar
Senior Member
Are you in Idaho too rob? I haven't seen the differential problem plague the GEMs p38s, only the Bosch for whatever reason. Sometimes they only make the noise at specific speeds or under specific conditions... its just a weird problem. Some owners have gone over 100k miles with the noise and have yet to have a real issue.
Old 10-12-2009, 03:01 PM
Senior Member
I am up in Coeur d'Alene.
I had not heard of the diff issue before so I have no help there. I have had Power steering pumps make noise when cold and the belts sometimes but that is about it. I have also only ever owned GEMS motors so I am not much help on the BOSCH, although I have owned a few BMW's so they cannot be that different.
Old 10-12-2009, 11:23 PM
Rhino1's Avatar
Member
Default Well?!?!?!
Okay , I thank you all for responding to my thread. And a Huge WOOOT!! to all the Gems in the Forums! LOL!! We should have lunch. Anywho, Get back from Lyle Pearson, and 300.00 bones later. My Water pump bearing is loose and going out. Along with the front crankshaft oil seal leaking and on and on. Well Lyle Pearson strategy could cost me a couple grand more. Of course on top of that, i ask them to do a oil & all around filter change. So they right on the invoice, Needs new engine air filter and cabin air filter. (ISN'T THAT WHAT I TOLD YOU TO FIX!!) frustrating. wish there were an independent near by. would save soo much money. Still didn't figure out what the howling was. Guess i have a Wolfenstein version of the RR huh? !! LMAO!!
Cheers!!
Old 10-12-2009, 11:32 PM
Senior Member
So they couldnt tell what the noise was?
If you can turn the wrench then replace the water pump yourself and do all the rest of the service too. The problem with dealers is that they want to fix everything before they really get to the problem, in case it may have some affect on the real issue.
Old 10-13-2009, 02:01 AM
LRScott's Avatar
Senior Member
I take mine to Greg's Autohaus. They aren't much cheaper than LP though. Most of the work that is done on my rover, is by me.
Old 10-17-2009, 02:09 AM
LRScott's Avatar
Senior Member
Hey rhino, did I see you on the road today? I saw the same p38 over and over these past few days that seemed to be going to and from the nampa area. Don't know if it was you, I turned my lights on after leaving a neighborhood, and saw the p38 for the 4th time on Chinden.
Thread Thread Starter Forum Replies Last Post
Engine noise 2000 disco II lndrover@carolina.rr.com Discovery II 6 05-01-2015 12:27 PM
Tonight on 'Name that noise!' Disco II makes intermittent popping/chugging noise VID bradman951 Discovery II 9 04-27-2013 02:18 AM
abs...codes...and rumbling noise + ticking noise 30more Discovery II 3 05-28-2012 06:01 PM
engine noise in front of engine Eulogio General Tech Help 3 01-21-2008 05:17 PM
'Bearing noise' coming from rear, droning noise? adrianwood Freelander 3 06-13-2005 09:53 PM
Tags
46, accelerate, back, crankshaft, discovery, engine, expedition, howling, land, leak, noise, rover, rr, sound, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
