Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 11-09-2011, 12:56 PM
Member
Default 2001 HSE Radio Issues
I'm trying to figure out the culprit to my radio issue.
I have power stations am/fm tune even cassette plays but I have no volume. I was thinking possibly the AMP is bad but the navigational audio is still coming through. Could this still be the amp and is this the amp located in the cargo area passenger side. Anything else I should check.
Old 11-09-2011, 01:24 PM
Senior Member
See attached from RAVE, says from 2000 on... If you misplaced your copy the download of the whole package is free below. Has tech, electrical, owners manuals, etc.
__________________
Old 11-10-2011, 04:03 AM
LRScott's Avatar
Senior Member
The amp could be bad, I have heard that the head units go out more frequently. At least mine did . You might consider taking it to a radio shop and have them see if the amp is in fact bad. I don't know if you know someone else with a rover, but if you swap a good head unit into yours, and it does the same thing. Then that at least rules out the head unit. I would also check ebay for used units as well. Got a good one there for a great deal.
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
Old 11-11-2011, 06:34 AM
Senior Member
Look in the L/S cargo area in front of the amp and subwoofer. I've seen the wire harness short on the body underneath the sound absorbing padding. I forget where the amp fuse is you would want to check that first.
__________________
Mike G
It's never over with a Rover...
06 LR3 W/G4 Accessory Package 94,000mi
04 Disco 2 128,000mi For Sale
99 P38 Bosch 70,000mi
66 GTO Convertible 427 Chevy
08 Buell 1125R
01 Kawi Concours
Old 11-11-2011, 07:16 AM
Senior Member
There may not even be a dsp amp in your vehicle. The subwoofer amp wiring may be shorted. The fuses you should check are in the becm under passenger seat. F1 F8 F15
Old 11-30-2011, 08:02 PM
Member
Ok so does the amp located in the subwoofer power all the speakers?Maybe that is my problem...
Old 12-02-2011, 06:10 AM
Senior Member
I just traced one of these out last week. The DSP amp powers all the speakers, and it is behind the subwoofer.
The sub has its own internal amp but is still driven thru the dsp amp
If you have 12v to the purple wire and the brown wire, and have a good ground black wire
(refer to rave for pin locations) you'll probably need an amp.
Don't bother trying to open it up you'll never find the problem unless you're an electrical genius.
__________________
Mike G
08 Buell 1125R
01 Kawi Concours
Tags
01, 2000, amfm, amp, amps, dsp, forum, good, hse, land, location, p38, radio, range, rover
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
