Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 01-15-2012, 07:40 PM
Member
Default 2001 HSE SRS Air Bag Fault Error
Arhhh, Another error alert on my dash. Can't seem to clear this one. Any advice? Someone had mentioned the wiring under the drivers seat???
AB
Old 01-20-2012, 02:52 AM
LRScott's Avatar
Senior Member
I believe it is a yellow connector under the seat that can get dislodged occasionally. Other than that, you might need to hook up a code reader. I believe the SRS system throws codes... Not 100% though.
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
Tags
2001, airbag, fault, land, rover, srs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
