If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
Im new to the site and need some help asap!!!!
I have a 2003 Range Rover big body and my antifreeze is leaking really bad and the mechanic states I need to replace the water pump. Can someone help me with some instructions on how to replace it. Do I need to replace any hoses with it
Also i found one one the web for $200, would that be about the right price for the OEM replacement.
depending on mileage those hoses are known to blow especially the top hose. that water pump is pretty basic just make sure you replace the water pump oring seals to the rear coolant manifold pipes. remove fan shroud and fan, remove pulley and remove belt. its pretty basic after that. couple bolts and it comes off.
Thanks for all your help, do you know of a good site for me to get the original water pump from... I see a lot of cheap ones and expensive one... Which do I chose, or do I just match the part number #8510324 from the dealer
Thanks [
QUOTE=socalrovershop;262863]depending on mileage those hoses are known to blow especially the top hose. that water pump is pretty basic just make sure you replace the water pump oring seals to the rear coolant manifold pipes. remove fan shroud and fan, remove pulley and remove belt. its pretty basic after that. couple bolts and it comes off.[/quote]
Check out sites like Rock Auto and AutohausAZ, compare prices with traditional guys like Atlantic British and Rovers North and bputah (british parts of utah).
