2011 RRS engine stutters
Old 03-27-2017, 02:52 PM
ktmnoel's Avatar
5th Gear
Default 2011 RRS engine stutters
Having an issue with my 2011 RRS with just under 100K miles. It has developed a stutter or hesitation at low RPMs(1500-2000) while under a load (going up a incline) as you slowly accelerate. You can also see the RPM needle move up and down by about 200 RPMs when you are trying to keep a constant speed.
I had the dealership look at it and they told me it was an engine issue and not a transmission issue. They told me that I had to replace my K&N filters and after market smaller supercharger pulley before they will take another look at it. I have replaced the filters and that didn't make a dent in the issue at all. In my personal opinion is I don't think changing the pulley will fix the issue but might not have any options.
Has anyone had this same issue??
Old 03-27-2017, 06:37 PM
LR Techniker's Avatar
Sounds to me like an Ignition Coil issue, but thats just a guess. Any fault codes stored in the engine or transmission?
Old 03-28-2017, 02:34 PM
ktmnoel's Avatar
5th Gear
No faults on the dash. Dealer said nothing showed up on there computers.
Old 07-26-2019, 01:31 AM
juzsymo's Avatar
I have the same issue, did you fix it and how?
Old 02-22-2020, 04:11 PM
Has anyone solved their issue? My wife’s full size supercharged has this same issue. Dealer was t able to find anything as there were no codes. Possibly unrelated but recently it has thrown the following codes but they go away on their own.
PO302
PO316
PO159
Any ideas? Bank 2 O2 sensor recently replaced. Cylinder 2 spark plug inspected and looks good, same as cylinder 4.
My wife loves this car so would like to make sure that it runs right and is reliable.
Old 02-23-2020, 08:59 AM
juzsymo's Avatar
The issue for me was a transmission that started to slip. I had the transmission rebuilt and the issue went away.
Old 02-23-2020, 09:42 AM
I am hoping that is not the case. 70,000 mile car. Transmission serviced at 60,000 by Land Rover dealer. If that is the case I’m assuming that the CEL is an entirely separate issue.
540is
01-23-2017 02:52 AM
dusty1
08-21-2014 09:12 AM
bmwrovers
07-14-2012 01:12 PM
M.Burroughs
06-17-2010 11:00 AM
XBlade
10-15-2009 09:39 AM
Quick Reply: 2011 RRS engine stutters
