Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 12-18-2011, 08:39 AM
Junior Member
Default 89 classic stalling
this thing is killing me, it stalls after running for a little while. mainly at stops and wont crank till cool.heres what i have replaced. coil,distributer,plugs and wires,fuel pump,computer,fuel pressure regulator, fuel filter,fuel temp sensor,coolant temp sensor,idol control valve. i dont know what else to try,any ideas?
Old 12-18-2011, 09:51 AM
Senior Member
A few different things come to mind.. Please bear w/me im going from memory 25 yrs ago..
Model Year 1989 may not have the first option
At the firewall on the passenger side (about the same height as the valve cover there
is a battery post where your b+ wires bolt to it is insulated with plastic and goes to the inside electrics of your vehicle. It supplys power to every . It could be loose or melted. be careful here it's live battery and if it shorts to ground... well I don't think I need to say more..
Under the passenger front seat there is a fuse block with 4 fuses and a seprate one with 2. IIRC the one with 2 fuses has the fuel/and or ignition circuit. make sure the fuses and connections are clean and the connectors are properly latched into the fuse holder a backed out connector can cause an intermittant running problem.
There are also 2 metal relays, one in a blue holder and one in a black holder. These are your fuel pump (blue) and you main (black) relays. You could check conncetions there and/or replace them.
In the lower L/F "A" pillar under the pillar trim there is a connector that supplies power to the fuel pump that can corrode or burn causing an intermittant running problem.
In the R/S rear headliner there is a buffer. looks like a big resistor with 2 black connectors. Disconnect that and plug the 2 ends of the harness together.
Thats all I've got. Hope one of these suggestions will help solve your problem
Cheers
__________________
Mike G
It's never over with a Rover...
06 LR3 W/G4 Accessory Package 94,000mi
04 Disco 2 128,000mi For Sale
99 P38 Bosch 70,000mi
66 GTO Convertible 427 Chevy
08 Buell 1125R
01 Kawi Concours
Old 12-18-2011, 03:48 PM
jafir's Avatar
Senior Member
Do you really mean it won't crank after it dies, or do you mean it cranks but won't start after it dies?
Amplifier Module Relocation Kit | Land Rover Engine Parts at RoverParts.com
__________________
______________________
Jafir
2003 Discovery S, 132K
2004 Acura TL
1999 Discovery II, 110K (Project)
Old 12-19-2011, 07:29 PM
Junior Member
i can turn the engine over for a few minutes and it will fire up but then it stalls again and has a strong smell of raw fuel ???
Tags
89, classic, cold, coolant, forum, fuse, gauge, range, rover, running, sensor, stalling, start, temperature, tool
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
