Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 06-23-2011, 02:21 PM
Junior Member
Default 95 RRC starting to sound like air-cooled VW!
Having (hopefully and finally) found the cause of the stalling issue, I have another one, the truck is starting to sound like a air-cooled vw - as if there was a hole in the exhaust or headers, loud and throaty.
I've checked everywhere and I don't see any gaps or holes in the exhaust.
It might be coincidence but it also seems like I'm not getting as much power either.
Am I missing something obvious?
Thanks
Old 06-23-2011, 07:44 PM
Cosmic88's Avatar
Senior Member
Are those cats old or new? Could be cats falling apart internally and clogging up your flow... Too much backpressure.
__________________
Cosmo - FLRC, President
http://www.floridalandroverclub.com/
-'66 IIa 88", -'94 RRC LWB, -'95 Disco 5spd
Download WORKSHOP manuals here -
http://www.landroverresource.com/ &
http://www.landroverweb.com/landrove...rover-manuals/
~"My grandfather rode a camel, my father rode a camel, I drive a Mercedes, my son drives a Land Rover, his son will drive a Land Rover, but his son will ride a camel." ---Rashid bin Saeed Al Maktoum, former Emir of Dubai
Old 06-24-2011, 10:56 AM
Junior Member
Default Cats
Quote:
As I have no idea how old they are, and the rear muffler recently disintegrated, I'm going to guess old.
Anything I should aware of when replacing in terms of OEM vs. aftermarket, etc?
Old 06-24-2011, 12:10 PM
Cosmic88's Avatar
Senior Member
I'd prefer to remove the cats from the equasion entirely but I live in a state where that is easy to get away with... no testing.
I hear good things about the borla and magnaflo stuff... honestly I am not a "brand" expert or anything so whatever is good for the price. Just make certain you have all your tune up stuff in order. Meaning, make sure you don't have any current issues causing your air: fuel mix to be overly rich. Rich running and any good amounts of raw fuel like excessive engine cranking with no spark) running through the cats will degrade the catalyst materials and then you will have wasted some hard earned $$$.
__________________
Old 06-30-2011, 01:30 AM
nkg nkg is offline
Junior Member
Hello
Have you checked the exhaust manifold gaskets? I had the rear one go, just a pin hole, but it made the engine sound as thought the tappits were coming out.
If someone hadn't said, put your hand round the back of the engine and see if the exhaust is leaking where the manifold is bolted on, I wouldn't have found it. I was all set to pull the head off and do the cam, followers etc.
NKG
Old 06-30-2011, 08:25 PM
Junior Member
Default I think you're right.
Quote:
Originally Posted by nkg View Post
Hello
NKG
I think I might have a leak on the left side. Happy it's not something more sinister, though I never look forward to extracting exhaust hardware!
Thanks for the suggestion.
Tags
air, aircooled, audio, clacking, cooled, discovery, land, landrover, problems, rover, rrc, sound, stall, starting, vw
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
