In response to 99 range fires and runs but does not move
Old 10-22-2008, 10:08 PM
tacomatech's Avatar
Default In response to 99 range fires and runs but does not move
ASP 500 Error
An error occurred processing the page you requested.
Please see the details below for more information.
[align=center]
Program File Name
/postpro.asp
COM Error Number
-2146824867 (0x800A0D5D)
Error File Name
/postpro.asp
Line Number
269
Brief Description
Application uses a value of the wrong type for the current operation.[/align]
pxlSiteFile = "landroverforums.com.js"; pxlScriptStart = '%3Cscr' + 'ipt type="text/javascript"'; pxlScriptEnd = '%3C/scr' + 'ipt%3E'; if (location.protocol.indexOf("https") == -1) { document.write(unescape(pxlScriptStart + ' src="http://pxl.ibpxl.com/'+pxlSiteFile+'"%3E'+pxlScriptEnd)); } else { document.write(unescape(pxlScriptStart + ' src="https://pxlssl.ibpxl.com/'+pxlSiteFile+'"%3E'+pxlScriptEnd)); }
var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
var acct='UA-939292-23';var ggIntvl;function loadGoogleFunctions(){if (typeof(_gat) == 'undefined'){ return; }; var pageTracker = _gat._getTracker(acct); pageTracker._initData(); pageTracker._trackPageview(); clearInterval(ggIntvl); ggIntvl = null;};if (typeof(_gat) == 'undefined'){ggIntvl = window.setInterval("loadGoogleFunctions()", 200);}else { loadGoogleFunctions(); };
_qoptions = { tags:"Automotive" };var _qacct="p-f3Hr4xDGnlZIE";var qIntvl;function loadQFunctions(){if (typeof(quantserve) == 'undefined'){ return; };quantserve(); clearInterval(qIntvl);qIntvl = null;};if (typeof(quantserve) == 'undefined'){qIntvl = window.setInterval("loadQFunctions()", 200);}else { loadQFunctions(); };
This kept coming up two days in a row when trying to respond to previous post about 99 range rover fires and runs but doesn't move.
-The engine ecu does not come preprogrammed and when replacing it, a fault might have been set in the transmission or transfer case ecu. Try disconnecting the battery for about an hour, then reconnecting. This should clear faults.A gear selector issue is possible, but would be pretty coincidental.
giboulou13
11-01-2010 07:37 AM
yevgenb
LR2
03-25-2009 11:10 AM
nathan214
10-21-2008 06:21 PM
Quick Reply: In response to 99 range fires and runs but does not move
