ABS Pump Replacement
Old 06-23-2010, 08:11 PM
bigtimer24's Avatar
Default ABS Pump Replacement
Hi All,
I recently had the abs, brake, and TC lights come on. It ended up being the ABS pump. The replacement was straight forward. Here's my question. Why is my brake pedal still going to the floor where I have to pump them 2 times to stop. Do I need to bleed the pump or the brakes? I have no lights on my dash since replacing it. Just wondering...
Old 06-23-2010, 10:44 PM
wilson96rr's Avatar
Did you follow the brake bleeding instructions in the manual step by step? If not, then that's most likely the problem.
Old 06-24-2010, 12:37 AM
LRScott's Avatar
Sounds like there is a bunch of air in the system. Here is the proceedure: http://www.rangerovers.net/maintenance/brakebleed4.html
jy3
06-04-2009 02:50 AM
barranr
06-03-2007 06:36 AM
cottonpatchweims
02-10-2005 07:18 PM
cottonpatchweims
01-14-2005 01:59 AM
Quick Reply: ABS Pump Replacement
