Any idea what could cause this EAS/Climate control issue??
Every so often, my climate control will just shut off... screen and everything... just blank... fan shuts off etc. With this, the EAS lights will shut off also... It seems to happen around the same time the ACC fan cuts on... but that could be coincidence... Please? Anyone?
My $.02 with the British the best way to handle an electrical problem is to once a year pull ALL the fuses and relays, spray contact cleaner in the block and on the relay pins and fuses. Allow to dry then put it back together.
NEXT find the ground points that connect to metal, break them loose, POLISH the steel and the connector and put back together.
I do the above with all my cars that are British and it does help a LOT.
collin Barrows
Audio/Visual Electronics
08-22-2011 10:22 PM
0304Disco
05-19-2011 03:18 PM
