Pressure washers can cause problems if the fuse/relay box was sprayed too heavy. Mine started smoking when I did mine... I un-plugged the battery and let it dry out. Everything was normal afterwards. If your friend can park the rover in a warm garage and let it dry for about 8 hours or so, that might fix the issues. If it does not, the electrical system might have been damaged.
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
