Cranks but won't start. PLEASE HELP!!!
Well if it cranks, you need to check the fuel pressure. This a little like the fuel pump. The L322s use ignition coils on ever cylinder I believe, so I doubt that is the issue. It could be a crank shaft position sensor, but I would test the fuel pressure first before throwing parts at it.
i'm not getting 12v to the fuel pump relay. Any suggestion.
Thanks very much.
dmatranga
02-05-2013 12:27 AM
