Did you hear the one about the RR with the powersteering leak?
Old 01-17-2011, 08:59 PM
Landifan's Avatar
Default Did you hear the one about the RR with the powersteering leak?
You all won't believe this!
My 95 RRC LWB has a power steering leak!
Previous owner was pretty sure it was a hose, but cleaning everything off then turning the wheel, I found fresh "blood" by the steering input shaft on the PS box. On rangerovers.net I've read about the Lucas stop leak, so I thought I'd try it (since even a rebuild is realistically 3-4 months out for both time and money reasons). Anyone have experience with it.
I drained the reservoir, which yielded about 12 oz of fluid, then replaced with probably half and half of the Lucas stop leak and new fluid. The leak has slowed, and things don't smell like hot dextron any longer, but there still isn't much assist when I'm not rolling.
no squeals, no noise.
Any thoughts?
thanks.
Old 01-17-2011, 09:38 PM
krazzz's Avatar
Mine has been full of Lucas for over a year now and the steering is much smoother than when I bought it,
Old 01-17-2011, 11:09 PM
LRScott's Avatar
I'll have to try that then.
The classic is known for its PS leaks. I would consider the system mediocre at best. Idk why they chose a crap PS setup, they just did . Most classics I drive tend to need a good crank to get the things to turn. As long as its not spraying out, just let it mark its territory.
Old 01-17-2011, 11:38 PM
handsome rob's Avatar
I think if you leave the Lucas in it may slow it down enough to get by until you can do a rebuild. They all seem to leak and that is part of Rover life.
Old 01-18-2011, 08:59 AM
Landifan's Avatar
Yeah, I know they all leak. So did my '88.
I'll have to see if its still leaking out. so far, I've not had to add anything, which was atypical prior to adding he Lucas, so the snake oil has definitely slowed things down.
overall things seem better...
thanks y'all
Adam78
06-01-2015 09:05 AM
calebbo
10-12-2011 09:54 PM
Disco2001
09-20-2011 11:11 AM
jrm123180
04-15-2010 12:41 PM
Quick Reply: Did you hear the one about the RR with the powersteering leak?
