Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 07-26-2011, 06:22 AM
drowssap's Avatar
Senior Member
Default good vs bad range rovers
well now that I have my Disco my wife wants a range rover, who would have guessed. She only travels 10 miles a day to work and if it gets me out of driving her everytime it snows it would be worth it.
I assume that there are good and bad range rover just like there are good and bad (03) discoverys. I will probably be looking 2002 and older simply because of the pricing on them.
Can some one give a quick run down on what to look for and what to stay away from. I noticed that a lot tend to have rust inside the rear door dog legs, it that just certian years? Also it may sound dumb but what is the difference in a classic and a p38?
__________________
00 Disco 4.0 80k miles SLS, ACE, 7 passenger 255x65x18: Repairs since 02/11 new intake, valve cover, head, timing cover, waterpump & oil sump gaskets, new timing chain & gears, water pump, t-stat, hoses, belt, new front drive shaft, Akebono pads, D&S rotors, SS brake lines, clutch fan, HMS completed.
90 RRC County
67 mustang GTA
73 Jeepster Commandos
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
He who dies with the most toys, WINS
Old 07-26-2011, 11:31 PM
Senior Member
how much do you ,have spend?
If it was me i would be looking for an 05 the best of the 03 to 05 BMW engined models, touchscreen nav. and fiber optics connectivity. Look at CL in Los Angeles they are pretty inexpensive.
I dont want a P38 as there are way too many issues, yes you can fix most of them but the biggest issue I found is the Rover splitting block engine, and or headgasket failure modes
Old 07-27-2011, 12:36 AM
collin Barrows's Avatar
Senior Member
Collin Oscar Barrows
My dad has a P38, Its been reliable for the most part, but the air bags did go on him a couple a months ago ($1,200) for the spring conversion, The radio sometimes get loader when you try to turn it down, but I personally like the RRC, but than again I like trails and rivers. I believe the p38 replaced the RRC in 1996. I'm not %100 sure though.
__________________
Our fleet:
1960 Morris Minor Pick up (right hand drive)
The Tartus: 95 Disco with a full wilderness roof rack, 4 PIA lights on the rack, brush guard, with 2 fog lights, rear tail light guard, 2in Todco lift, Rhino Painted the cargo area, 5 Pro Comp 33in Mud Terrain Tires %75 tread, diff skid plate, and I'm only 18 ....
Bipolar: 2000 p38 Range Rover Brush guard, rear lamp guard, new grill, coil suspension.
Old 07-27-2011, 12:05 PM
Member
A Land Rover for each of you? Do you have a reliable 3rd car as a back-up when your Disco and her RR are in the shop (ha!). There are so many different kinds of issues with P38s but mainly they relate to the EAS system I would say. Air bags, compressor, valve block, etc. I had several coolant leaks & oil leaks. Electrical gremlins are common, too. Then add in normal maintenance and this truck can be a lot of work and $$ to maintain. Finding one that has been meticulously serviced is really key here. I didn't catch where you are located but if you can find a RR from CA or the Southwest, you'll avoid rust issues. You mentioned snow so probably not somewhere warm. Personally, I would stay away from the Classics as they are even more underpowered and since they are older, will likely have more service that will be needed to keep them road worthy. Like the other poster stated, I would opt for a newer model, like an 04' or 05'. 2006 was the introduction of the Jag engine but these are still pretty pricey. My advice would be to go as new as possible so 2002 and opt for the 4.6 HSE, not the 4.0 SE. The 4.6 is a little more powerful.
Old 07-28-2011, 07:03 AM
drowssap's Avatar
Senior Member
thanks fellows,
I think i know most of the faults on the 4.0, having mne down to the short block already. And the ESA looks to be more problematic than even the SLS on my Disco, so i think a spring convertion is inevitable with them. As for two rover yes; i'm a gluton for punishment. But that is what the jeepsters are for, i let them sit for 6-months sometimes over a year hit them with starter fluid and they start right up and go down the road like they were driven yesterday.Plus a antquies it cost me pratical nothing to register.
__________________
90 RRC County
67 mustang GTA
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
Old 07-28-2011, 04:09 PM
yloDiscoII's Avatar
Senior Member
CLASSIC (LWB) [up to '95)
P38 ['95-'03]
MKIII ['03-??]
__________________
Rob
2002 DII Kalahari (139K)
“We do not accept that ours will ever be a nation of haves and have-nots; we must always be a nation of haves and soon-to-haves”
Old 07-29-2011, 05:02 AM
drowssap's Avatar
Senior Member
thanks got to love that RRC
__________________
90 RRC County
67 mustang GTA
69 Honda SOHC
71 HD FX
72 BSA Lightning
73 Honda SOHC
78 Honda SS
87 HD FLTP
2004 HD SE 103
Old 07-29-2011, 02:43 PM
Member
I can tell you from experience that the ride of a RR with the coil spring conversion sucks compared with the EAS system + it's not cheap either. I think it cost me a $1K and I immediately realized the ride was not as good. I guess the upside was no more EAS fault codes or walking to the truck in the morning and seeing it on its bumpstops or even worse, driving somewhere and having it drop to the bumpstops. Talk about a double whammy of being embarrased and feeling every little pebble you run over. When I see someone driving a P38 and their truck has dropped like that, I just think to myself, oh that poor SOB (ha ha).
Old 08-09-2011, 01:46 AM
LRScott's Avatar
Senior Member
The ride is definitely worse with coils, however you are eliminating many of the issues associated with the P38 by getting rid of the air ride. Seeing as you are a discovery owner, you already know how to treat a rover and understand that they require a little tinkering from time to time. As for the block and head gaskets, you will encounter the same issues on the BOSCH rovers that you will encounter on the BOSCH Discos. After all, they use virtually the same engines (aside from the classics).
As previously said, the MKIII rovers tend to be more reliable, but when they do break the the repairs are usually more expensive. At least this has been my observation. In either case, keep us posted.
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
Old 08-09-2011, 12:30 PM
Senior Member
For offroading, the classic is really the only option. Upgrading the P38 or later you will run into serious limitations that can really only be overcome by fabricating stuff beyond what it's worth to keep much of anything you started with. With the Classic from the 90's, you have a lot of the same components as a Discovery 1 or Defender 90. You'll have the LT230 transfercase, (in NA) the V8 and the ZF HP-22 transmission, the Rover axles and the spring perches, shock mounts, radius arms, trailing links etc are much the same so there is a lot of aftermarket support for all of these components. Not so with the P38 and later.
But I don't get the sense you intend to offroad the Range Rover. In that case, I imagine the later models would be better, but in that case, why not a Lexus or whatever? The more recent, the more refined they will be, but I suppose it would come down to determining your budget and getting the nicest one for the money.
Tags
bad, cargo, connection, cover, good, land, landrover, p38, perches, range, rover, rovers, rr, snow, spring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
