Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 06-26-2011, 08:43 AM
Senior Member
Default Hatch latch locking troubles
by Mrmerlin » Sun Jun 26, 2011 5:41 am
2005 HSE the hatch unlock lock cycles about 3 times when the remote is pushed ,
and the top portion of the hatch wont fully unlock unless the door is pulled ,
after readjusting the lower door and upper door now the cargo lights wont go off.
Also when closing the top sometimes the door will close but not latch then pop open then close and latch
kinda like its bouncing off the latching mechanism and not latching then on the second bounce it latches.
The hatch was working fine then this whole thing starts going on./
Does anyone have any ideas what might be causing this,
The top hatch latch is really put together well and i am reluctant to try to take it apart as its riveted together, but that might be the next step
How much is a new part?
Old 06-28-2011, 07:26 PM
Senior Member
look at the striker to make sure its not loose. if its loose then pop the small caps on the end of the bottom door and take the screws out and pull off the trim and tighten down. just make sure to line the door up right.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Tags
closing, door, hatch, land, latch, latching, lock, loose, range, rover, screws
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
