Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 11-28-2011, 10:44 PM
Junior Member
Default Help, Help...2003 RR Battery (charging) issues
Hey guys, I need for help. I have a 2003 RR HSE (103,5000 miles). My battery light flashes on and off (about every 3-4 minutes) after a new alternator and new battery. The instrument panel lights continuously dims? Also, the radio cuts on and off. What could be the problem (s)?
Old 11-29-2011, 04:40 AM
Senior Member
Belt route, check first, if wrong can screw up other things as well, like cooling system. Pages attached from RAVE.
New alternator is bad or failing, check volts across battery. Would expect 13.8 - 14.4 volts engine running, no major accessories on. Rebuilt alternators from big box parts stores are famous for failing. If this is your replacement, be sure to save receipts.
Also could be bad or dirty terminals, either at battery, main frame ground (follow negative to ground spot in battery box). Battery ground may have been moved when replacing battery, needs to be clean and tight. See attached.
Bad ground connection from battery to frame, or frame to engine, can make volts go high or low, and high (above 15 volts) is very bad for electronics.
Also ***** read this from RAVE before work!!!!
Charging
The charging system comprises a battery and an alternator. The battery must be of a
sufficient capacity to operate the starter motor and operate the various electrical systems in
the vehicle. The alternator charges the battery when the engine is running and increases its
output as demand on the battery increases.
CAUTION: The battery positive terminal uses a pyrotechnic attachment which
detaches the battery cable in the event of a crash severe enough to trigger the
airbags. Refer to the Supplementary Restraint System section of the System
Description and Operation Workshop manual for further details.
The alternator is located at the front LH side of the engine. The alternator has an output of
90/150 Amps and is manufactured by Bosch. A polyvee belt drives the alternator pulley,
which in turn is driven from the engine crankshaft pulley.
The instrument pack incorporates a charge warning lamp which illuminates when there is no
output or a low output from the alternator. For a detailed description of the starting and
charging system, refer to the Engine Management System – V8 section of the System
Description and Operation Workshop manual.
__________________
Old 12-03-2011, 10:57 AM
Junior Member
Thanks SB. I'm going to look at those possible issues.
__________________
11' BMW 528i
03' RR HSE
02' Accord
99' Disco II
Old 12-03-2011, 12:31 PM
Senior Member
I'd look at battery (-) wire, which they may have had to remove from chassis to swap battery, and may have not tightend back up on the ground point. Everything is so compact under the hood that the average mechanic has to go outside to change his mind...
__________________
Old 12-03-2011, 07:18 PM
Junior Member
My mechanic said that he checked the wires connecting the alternator including the (-) cable wire. Fustrated, I took it to the dealership today. I'm waiting on the diagnosis. :-(
__________________
11' BMW 528i
03' RR HSE
02' Accord
99' Disco II
Old 12-07-2011, 09:17 PM
Junior Member
did you turn the steering wheel all the way to the left ...then all the way to the right to set the computer after the install.
Tags
03, 2003, alternator, battery, cable, charge, charging, hse, light, problems, pyrotechnic, range, remove, rover, rr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
