Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 10-30-2011, 08:51 PM
Member
Default Help please...
I purchased a 97 Range Rover 4.0 today, the good: good body, paint and interior the bad: after owning for less than 2 hours, wont start. I have fuel at the rail, it attempts to start and dies. I have a Disco 1 as well. I am so furious and at a loss of words. Paid $2100 previous owner, he replied earlier and now nothing. I was told its a fuel pump, is this an easy fix if its the issue? I have spray at the fuel rail, unable to check codes, luckily this happened at a Walmart.
Old 10-31-2011, 06:10 AM
Senior Member
You may have fuel at the rail but no pressure. Who told you it needs a fuel pump?
Do you have spark at the plugs?
It could be as simple as an inertia sw, fuse, bad main relay or fuel pump relay.
With no diagnostic tools I would check these first. Fuse 37 10amp, and 39 30amp and Relays are in the engine compartment fuse box. When you flip the cover over you'll see a graphic of a gas pump, that is the fuel pump relay. the ignition relay RL19 may have an engine graphic or may not. It should have RL19 written on the cover (center yellow relay next to the maxi fuses). inertia sw is in the r/s kick panel.
__________________
Mike G
It's never over with a Rover...
06 LR3 W/G4 Accessory Package 94,000mi
04 Disco 2 128,000mi For Sale
99 P38 Bosch 70,000mi
66 GTO Convertible 427 Chevy
08 Buell 1125R
01 Kawi Concours
Old 10-31-2011, 03:24 PM
LRScott's Avatar
Senior Member
You need to get a gauge on the fuel rail and see what pressure it is at. Even when mine had sat for a few days I still got spray when I went to depressurize the system for a filter change. I wouldn't consider a fuel pump "easy". I would try to rule out the possibility by checking everything else before I would replace it. $2100 sounds like a pretty good deal, even with the fault. Don't know if you signed the bill of sale with an "as-is no warranty" statement in there. If you did, the previous owner doesn't really have an obligation to do anything.
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
Old 10-31-2011, 06:30 PM
Member
I just walked to where she was parked, she cranked over just fine, now I'm even more confused.
Old 10-31-2011, 06:40 PM
Senior Member
OK, so if you have a Rover that won't crank after being warmed up, and when it cools off it will crank again and idle normally? Could be a sensor, and one that comes to mind is the crankshaft position sensor. It could also be fuel pump/filter/regulator related, and there is a schrader test valve on the fuel rail you can reach and put a gauge on. You'll need to borrow that from a big auto parts store, if you don't have one.
Have you downloaded the RAVE tech manual that covers your vehicle? Free below. Please be detailed in posts, what may seem like nothing to you may be a pointer at what is going on.
__________________
Old 11-02-2011, 12:41 AM
LRScott's Avatar
Senior Member
Are you referring to cranking or firing up? That kind of confused me because in the first post you said it would try to start and die, now your are saying it cranks fine... Also, have you checked the fuses or fuel pressure yet, as was suggested? You need to give us some info if you want us to start narrowing down the cause of the problem.
__________________
Old 11-02-2011, 01:08 AM
Member
I'm hoping to take her in tomorrow, I don't have the tools needed for to do this myself. Thanks for all the help this far.
Old 11-03-2011, 02:26 AM
LRScott's Avatar
Senior Member
You don't have a tire pressure gauge? That is all that is required to see the fuel pressure when the vehicle is running. All you need to do is pull the fuses out and see if they are burned out or have cracks in them, as for the relays just swap them for known good ones... All that is required to do that is maybe a screw driver and needle nose pliers, otherwise you can usually use your fingers.
__________________
Old 11-03-2011, 04:28 AM
Senior Member
switching from DIY mode to "maintain by open checkbook".....
__________________
Tags
fuel, pump, rangerover, rl19
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
