How to connect air lines on new Air Springs
Old 03-05-2010, 01:23 PM
rich's Avatar
5th Gear
Default How to connect air lines on new Air Springs
I replaced my two front air springs a month ago. I still have a minor leak at the air connection on each of new air springs. I suspect that I did not push the air line in far enough during installation.
Can anyone share advice on how they make that connection? My hands are not small enough to get a good grip on the air line! Wonder if I should heat the tube to make it more pliable?
Thanks in advance
Richard
Old 03-05-2010, 01:56 PM
krazzz's Avatar
Did you lubricate the o-rings? Make sure the line is good and clean and the the surface is smooth. Did you use new o-rings?
Old 03-06-2010, 08:55 PM
handsome rob's Avatar
Check what Krazz said and then use some long needle nose pliers to push it in.
Old 03-07-2010, 12:21 PM
rich's Avatar
5th Gear
Default O ring!
Thanks guys.
I will try the pliers...HOWEVER..I did not see an o-ring at this connection? I did not use one during the initial assembly. Are you sure one is used at the connection to the top of the Air Suspension bladder?
Thanks
Old 03-07-2010, 02:52 PM
krazzz's Avatar
Yes, there are two o-rings on top of the bladders. the are between the housing and brass collet. You can also just put some vaseline on the hose before you put it in.
TRIARII
02-26-2015 11:13 AM
disco-montana
02-01-2011 12:14 PM
robson
12-28-2010 08:25 AM
pvenuti
04-17-2010 05:20 PM
Aj6543
12-09-2009 07:56 PM
Quick Reply: How to connect air lines on new Air Springs
