I am lost, 01 Cruise
Old 10-07-2010, 10:23 PM
georgep's Avatar
Default I am lost, 01 Cruise
I got the books and all but this Cruise Control has got me scratching my head.
I replaced the bad vac hose that attaches to the back of the actuator but not work.
Get the electrical light on the dash at the switch but NO indicator on the dash.
Any idea where to look next or is this a dealer fix?
Thank you
Old 10-08-2010, 06:35 AM
wilson96rr's Avatar
I have been through the troubleshooting guide in the Rave manual with mine. I also get the light on the button, but that is it. Did you go through the troubleshooting in the manual? It is step by step and easy to follow. Only problem that I had was after completing it, I still can't get the cruise to work. According to the troubleshooting guide, there is something wrong with my BECM, so, I just gave up. Hope you have better luck.
Old 10-08-2010, 08:34 AM
georgep's Avatar
Well I will do it again. I bought an Auto Xray OBDII system so just need to learn how to use it. That MIGHT help, came in this morning.
Old 10-08-2010, 02:21 PM
krazzz's Avatar
Do you hear a click under the dash when you push the button.
Old 10-08-2010, 03:18 PM
georgep's Avatar
NO CLICK CLICK. Relay?
Old 10-08-2010, 09:26 PM
wilson96rr's Avatar
I don't get a click either. I do know that the OBD scanner is not needed to troubleshoot the cruise.
Old 10-08-2010, 09:28 PM
krazzz's Avatar
There is a control module and power inverter under the dash. If it doesn't make the click it is probably one of those two. I had the same problem. I was able to get both of them on ebay for pretty cheap so I just replaced both. I do have occasional problems with it kicking off but it doesn't happen very often and it works again if I turn it off and on again so I don't worry about it.
Old 10-12-2010, 07:38 AM
Chris X's Avatar
I'm in the same boat, I did the troublshooting manual in RAVE. Fairly straightforward although the wheel speed sensor check was a bit of a PITA. My inverter and cruise ECU tested out fine per the RAVE procedure (even though they do not "click"), so looks like BECM is my issue as well. I'm going to have the dealer take a look when it goes in for inspection next month, I'll post up if they find anything that is fixable.
Old 10-21-2010, 03:06 PM
georgep's Avatar
Well so far NO GOOD, tested, prodded, smacked it a couple of times and nothing.
Local shop says to look at the stop light switch which controls the cruise and is an NO switch that fails in the NO position, makes sense. Thta is my next crawl around to look at.
Back working on my Porsche to get the A/C and Stereo working, electrical gremlin.
bikingteacher
03-25-2011 08:00 AM
phill
05-17-2006 08:22 PM
NomadABC
03-02-2006 06:33 PM
sexualtrex
07-18-2005 08:03 PM
Hudas69
04-07-2005 03:55 PM
Quick Reply: I am lost, 01 Cruise
