Multiple Chimes After Start
Old 09-27-2006, 12:59 AM
akartis's Avatar
Default Multiple Chimes After Start
I was wondering if I could trouble someone with a question? My RR has had the coil conversion done and the EAS overide module from British Atlantic is installed. However, I still get numerous chimes after I start the vehicle. Is there some sort of directory or some thing that tells me how many chimes means what? Could this be related to the brake light and TC light staying on for a long period of time after start?
Old 09-27-2006, 09:02 AM
Default RE: Multiple Chimes After Start
Can't help you with the chimes but the t/c light and brake light shouldn't stay on longer. How long has it been since you changed your brake fluid or even checked it fluid level?
A good flush might help there.
Mike
Old 09-27-2006, 11:55 AM
akartis's Avatar
I checked the level and it is a little low. Very little. Would that cause the lights to come on? I will give it a good flush also since I just purchased.
Old 09-27-2006, 07:15 PM
esaycho's Avatar
While it is chiming does the message center say Seatbelt Please?
Old 09-29-2006, 03:38 PM
akartis's Avatar
There are only two things. The first is EAS Manual. I understand this is because the coil conversion was done and it has the override modual installed. The second is Washer fluid low.
Old 09-29-2006, 04:33 PM
esaycho's Avatar
Have you filled the washer fluid up?
Old 10-11-2006, 11:38 AM
akartis's Avatar
I have filled the Washer fluid.
Old 10-12-2006, 09:58 PM
esaycho's Avatar
Your sensor for the Washer Fluid tank could be bad
ninjaff21
12-21-2013 09:43 AM
Kingmarine
02-19-2012 04:28 PM
callmehero
12-07-2009 07:35 AM
Darover
11-06-2009 07:35 PM
SurfRat
10-13-2008 08:51 AM
Quick Reply: Multiple Chimes After Start
