Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 01-11-2012, 09:29 AM
Junior Member
Default my 2000 range rover wont start all the time please help
hi can anyone help my 2000 range rover dont always start it will one time then wont anouther please help me
Old 01-11-2012, 11:14 AM
Senior Member
Any check engine light on or codes stored?
Please describe in vivid detail, and when this happens (every moring when cold, only when you park after driving an hour, etc.).
Any noises (click, multiple clicks, starter growling or metal on metal noise, starter even turns engine (fan belt moves)?
How old is battery?
__________________
Old 01-11-2012, 01:46 PM
Junior Member
iv just had fan belt done as the tension wheel broke off. it starts in morning fine just seams to do it once been moved. iv not heard no clicking or any other noise when it dose this. it turns over just wont fire up iv not seen if fan belt turns i will look tomorrow not sure how old the battery is as only had car a week.i have all the luck i dont know if it has anything to do with it but i was driving it the other day and it just cut out and wouldnt start again i was low on fuel and thought it was that but when i got towed home it started so not sure now. also my remote dont work it lock the doors. there is no lights on
Old 01-11-2012, 08:45 PM
Senior Member
its the crankshaft position sensor. if you have to bring a bottle of cold water to pour water on the sensor to get it to fire up.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 01-15-2012, 07:43 PM
Member
Sound like it could be that CPS sensor. However, you have to think why this belt broke. As you stated the pulley tensioner was replaced. Could the AC compressor be seaizing up too causing the belt to tear up. Mine did the same thing.
Tags
2000, 2000land, ac, crank, cut, drove, fstart, land, landrover, oil, problems, range, rover, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
