P38- Need help removing drivers door panel.
Old 02-04-2010, 09:35 AM
LRRange's Avatar
4th Gear
Default P38- Need help removing drivers door panel.
Hey guys my window works good on its way down but when i go to put it back up it crooks forward slows to a halt then goes back down on its own. Only if i guide the glass by hand will it slide right into position. Im guessing the glass is off the track and I'd like to get inside the panel. Any help with this would be appreciated
Old 02-04-2010, 09:28 PM
LRScott's Avatar
You'll have to unscrew the the inside handle/armrest and then the latch (I think there is a screw on the latch, can't remember). The rest of the door cover is held on by metal clips which will require you to pry the panel off. Be careful, you might break the plastic part of the clip if you pry to hard to fast. Good luck!
Old 02-05-2010, 06:07 AM
Rovin4life's Avatar
needs either a regulator or adjustment. most likely a regulator.
Old 02-27-2020, 09:09 AM
Disco1inOxford's Avatar
In the process of removing the back door panel to get at the latch mechanism for the door handle. Is there any trick to removing that arm rest? Very little room to work that bolt head, I need to locate the right size driver anybody know the dimensions? Thanks!
redrover75
03-27-2018 09:24 AM
Bishop
05-31-2013 09:39 PM
cationmoted
12-04-2010 08:55 PM
hersrud
10-04-2010 03:44 PM
2000 Disco 2 SD7
11-19-2007 02:32 PM
Quick Reply: P38- Need help removing drivers door panel.
