Q About Replacing Shocks & Brake Light When Pressing Brake
Old 07-02-2007, 09:19 PM
bigbris1's Avatar
3rd Gear
Default Q About Replacing Shocks & Brake Light When Pressing Brake
For my second Range Rover I just brought home a 1996 4.0SE (my first was a 1997 4.6HSE Kensington). While the EAS works well on this Rangie, the ride home was a bit unnerving. I noticed that the front right side dips on bumps more than the rest of the truck. My first thought was that it's time to replace the shocks. Does this sound right?
Also, the BRAKE light, ABS light & TC lights come on briefly when I press the brake pedal. The brakes work find & the brake fluid it a little beyond the MAX mark. What could this be?
[align=left] [/align]
Old 07-02-2007, 10:00 PM
bigbris1's Avatar
3rd Gear
Default RE: Q About Replacing Shocks & Brake Light When Pressing Brake
Just went out & tested the brakes. I can hear the pump for like 2 seconds whenever I depress the brake pedal. Please advise.
Old 07-03-2007, 10:56 AM
The ABS warning lights are an indication that there is a problem developing and you should get it into a shop to have the codes read. As for the suspension, no it is not your shocks, although they are probably warn out if they have never been replaced, this problem also needs to be checked with a good scanner to determine what id going on with the suspension.
Mike
Old 07-03-2007, 08:02 PM
bigbris1's Avatar
3rd Gear
What makes you think it's not the shocks? What else could it be & how can scanning it determine the cause? Thanks!
LADEROUTE
11-06-2012 05:56 PM
br0keit
08-31-2012 08:13 AM
pit_ownr
10-30-2008 02:40 PM
kerbse
09-23-2007 01:23 PM
Quick Reply: Q About Replacing Shocks & Brake Light When Pressing Brake
