Range Rover P38 rec. oil, tranny fluid, diff fluid etc.
Old 03-03-2009, 09:03 PM
LRScott's Avatar
Default Range Rover P38 rec. oil, tranny fluid, diff fluid etc.
I have recently purchased a 1996 Range Rover P38 that has numerous leaks and what not (which of course is normal). Some of its fluids seem like they need a change, primarily the engine oil and possibly some of the diff fluids as well. I was wondering what kind of synthetic motor oil some of you guys with p38s like to use as well as the recommended/required differential fluid. I am also looking for the breather plugs on the differentials to make sure they are not clogged, Haven't had much luck, does anyone know where they might be at? (they are probably right under my nose). That and I can't find any record of the transmission fluid being replaced... I was wondering if it would hurt anything if I went ahead and replaced that as well and also with what kind of transmission fluid? Sorry about all these questions, I do not have a service manual yet but, I just want to get it road worthy and have the peace of mind that I will not be experiencing any sort of catastrophic power train failures in the near future. Any input is appreciated.
Old 03-03-2009, 09:56 PM
roverguy7's Avatar
i do not recommend synthetic, use normal, and change it regularly, as to the trans, good old atf, same for the tbox and the p/s. use heavy weight in the diffs, 80/90 or 70/90. if you dont know when the trans was done last, should probably change the filter too, there are a bunch of write ups on how to on here, its the same as a disco, just fill through the dipstick.
Old 03-04-2009, 08:39 AM
Here is a list for you to work from, there are a couple of items that might be different since I set this up for a Discovery, send me your tele number and we can talk more in depth.
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
12 Qts. of ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of synthetic DOT 4 Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant, also called DexCool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
Hoses and belts, as necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
jrotter
LR4
01-09-2021 09:20 PM
jrotter
11-22-2014 09:32 AM
achapman
06-25-2013 03:40 PM
06Range
05-08-2013 09:01 PM
TheBelly
11-01-2010 08:34 PM
Quick Reply: Range Rover P38 rec. oil, tranny fluid, diff fluid etc.
