Rear Window Screen Washer
My rear washer pump went out last week. Checked the connections and the anti-drainback valve, they were ok. Swapped out the headlight washer connector and line with the ones on the rear washer pump, and it that pushed fluid out to the window. So its a bad pump. Might want to try that trick to help troubleshoot.
Note, if doing this either drain the tank or prepare for a wet sleeve when you swap the rubber lines. I chose wet sleeve since that's the easier of the two.
Access is fairly easy by removing the right front fog light. Be prepared for a bit of a fight with that.
