RRC transer box / diff: how to test?
Hi,
I had my RR classic (1980 3.5EFi) on the rollers today having the brakes tested, and to my very great surprise, when the front wheels were being turned, the rears, which were on a bed of free rolling rollers, were stationary. Same with the fronts when the rear wheels were being turned.
Is this normal or is something broken? , I could swear last time it was done all 4 wheels turned at the same time!
The car was in N (it's an auto) and the diff-lock was off and in high ratio mode.
Can anyone shed any light on this?
Thanks!
Thanks!
That sounds normal to a certain degree. Essentially the way it is setup, only 2 wheels will move at a time. That is not the case with mine or some of the newer classics that have the viscous clutch, but as long as you don't hear any grinding noises I wouldn't be overlly concerned. With any differential setup, the wheel with the least resistance will turn. The center diff locker will keep that from happening between the front and rear wheels. At least that is what I am assuming.
WNYErikDiscoII
11-07-2013 09:32 AM
Lincoln Tarantino
05-02-2012 11:20 AM
Paul Grant
36
03-14-2012 07:59 PM
