AC condenser
AC condenser
Hello,
My AC condenser has a leak and I will replace it by myself.
I have one question: do I have to change the cooling fans in front of the condenser as well ?
When I turn the AC on, the fans are not turning. Is it normal or they have to always be turning when AC is on ?
Thanks,
Pat
Thanks,
Pat
What year rover? Did you spot the leak? Mine turned out to be a really simple leak and was fixed by tightening the bolts on the back of the compressor. If you are going to replace the condenser it is generally wise to replace the fans. Although, I believe they can be removed from the bad condenser and placed on the new/good one.
The fans do not kick on much (this is assuming its a P38) but will once the temps hit a certain level. Mine will kick on when the coolant hits 210F and then shut off after it cools to 199F. The engine driven fan does a good job of keeping things cool.
The electric fans reduce the high side head pressure on the compressor, and come into play at slow speeds or idle. At higher speed, normal airflow does the job. BE SURE if you replace them that the air flow is from outside thru condenser and on to radiator - not reversed. If reversed, your AC compressor will have extreme pressure (mine went to about 450 PSI), and vehicle will overheat as air is being pulled away from the viscous fan clutch. That fun clutch depends on air temp getting to about 170 before it begines to re-engage. Alaways change the receiver/dryer when changing the condensor - it removes moisture from the system and also acts like a filter to trap junk. My D1 has one smack in the middle of the condenser.
I went to Land Rover and ask for filling the AC with freon. Ac was working it was blowing cold air inside the car. After 2 days, the air was warm.
So I came back to Land Rover and they said that all the freon was gone.
Then they put a green liquid to show leaks. And it was coming from under the condenser.
When they gave me the price to replace it, I thought it was better to replace it myself.
The salvage yards around me offer that sort of thing for $50 or less, 30 day warranty, and you can purchase a six month warranty for a few dollars (like $4). Their warranty is money back or another one, or yard credit. But this is the sort of thing that will show up a leak as soon as you vac down the system and re-fill with R134a. An indy A/C shop might be a cheaper route to vac and re-fill if you don't have the time or equipment for that.
