What is the purpose of LOW RANGE
Old 11-10-2010, 10:18 PM
NAGA's Avatar
6th Gear
Question What is the purpose of LOW RANGE
hey guys i drive a 08 RRS and i was playing around with the settings and when i select mud, rust the car says to put it on low range!!! my question is what is the purpose of low range!!! help pls
Old 11-11-2010, 01:39 AM
LRScott's Avatar
Low range is a transfer case setting. Selecting it puts the transfer case in a lower gear setting. This will give you better control over the vehicle while it is climbing and descending steep hills. It also assists in limited traction situations. The idea behind it is to select LO range, and then ascend a hill in the highest gear possible (do this in sport mode). While descending, select the lowest gear possible. You will be surprised as to how much engine braking really helps you out. In situations where you are traveling above 25mph, putting the rover back in HI range is recommended. I only use HI range when my average speed is below 20mph and I'm climbing and descending steep hills. Sometimes I won't use it even in mud or snow. If I get stuck, then I use it . Sort of like a last ditch effort if you will. I get it stuck in HI range, then I know I've hit the limit and then use LO range to get me out of trouble. Have fun and happy trails!
Old 11-11-2010, 12:18 PM
krazzz's Avatar
Its also good if you want to remove stumps and pull your house off its foundation
It is something I almost never use but it is a good idea to put your truck into low every few months just to make sure that it goes in ok. I have heard of people who haven't used it in years and when they really need it, it is stuck in Hi.
Old 11-11-2010, 09:17 PM
NAGA's Avatar
6th Gear
wow thanks alot guys!! it really helped me alot to understand!!! ill keep u guys posted and will post some pics and vidoes of what i did!!!
Old 11-12-2010, 02:55 PM
handsome rob's Avatar
It is also used when you need that extra power. I have used mine many times depending on how steep a launch ramp is when pulling out my boat.
ajk150
Off Topic
11-16-2012 09:31 AM
b63215b
08-19-2012 05:40 PM
wilson96rr
01-03-2009 10:44 AM
cosmickites
Defender
12-24-2008 05:30 AM
Classic89
08-10-2007 08:58 PM
Quick Reply: What is the purpose of LOW RANGE
