Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 01-13-2012, 04:16 PM
Junior Member
Send a message via Yahoo to tonydiscovery
Default Wheel Bearing
Hi to you all.
A new member to the forum hear and already have a question so this will show how good this site is lol.
I am now the happy owner of a 1996 P registered Range Rover 2.5 DT & loveing every second of driveing her BUT..........
I need to replace the drivers side FRONT WHEEL BEARING which i got with the Range Rover.
Question is.....Im of the understanding that the bearing has to be pressed in and cant be done by a weekend d.i.y mechanic like myself SO i went to get a price and the local mechanic told me that he could not give a price untill it was stripped down AS IT MAY BE A WHEEL BEARING AND HUB COMBINED
But as i said i have a wheel bearing so could it be wrong and i need to buy the wheel bearing and a hub assembly together????
All info on this matter will gladly be taken on board AND ALSO what kind of price to be looking out for.
Many thanks.
Tony.
__________________
As happy as a landy in mud
Old 01-13-2012, 09:02 PM
Senior Member
you can do it yourself but its a whole bearing and hub assembly.
is it loose or noisy?
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 01-14-2012, 02:25 AM
LRScott's Avatar
Senior Member
Take the hub and wheel bearing assembly to the mechanic. They will be able to tell you if the hub is salvageable, if so they can press a new one in. If not, then buy a new/used hub as a replacement. They will usually (almost always) come with a bearing already pressed in.
__________________
A Land Rover doesn't leak! It marks its territory.
What do Jaguars and possums have in common? Both play dead at home and get killed on the road.
1996 Range Rover 4.0SE 167k Miles
1998 Jaguar XJ8 107k Miles
2003 Land Rover Discovery 114k Miles
2005 Jaguar XJR 52k Miles
Tags
03, 1996, 2000, assembly, bearing, bearings, braring, discovery, front, land, landrover, replace, replacing, rover, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
