Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
AC odor/ AC drain
Old 07-19-2014, 10:34 AM
Jmd1964's Avatar
Default AC odor/ AC drain
Mildew smell from AC first step to make sure drains are not blocked system is draining from one spot. Is there one drain on Evoque or two?
Old 07-20-2014, 11:30 AM
Jagfixer's Avatar
If you only see one on pass might be it. Parts store sells a can of odor remover you spray into vents and A/C intakes. Find your cabin filter and change. Spray A/C intake while running A/C and use as much of can as possible. BG makes a good one but you have to find a dealer. Leave windows down to let air out when done.
Old 07-22-2014, 07:09 PM
G Reeves's Avatar
What year is your Evoque? There was TSB regarding smells coming from the A/C due to the glue resin used for bonding the unit with RR Sports and there might be one for the Evoque as well. Check with your Land Rover dealership
Old 09-08-2014, 01:00 AM
saqlain1122's Avatar
Default sm
Old 12-09-2014, 08:26 AM
js8488's Avatar
Thankfully I have not experienced this odor your speak of? but good to know about the glue resin for the future... didn't know that. Thanks
Old 05-23-2019, 08:45 PM
HypeDawg4Life's Avatar
Default Locating intake for AC
Where is the air intake located on a 2013 Range Rover Evoque for the AC or outside air?
rovingaz Ryan
09-09-2019 01:47 PM
hugo81
04-28-2019 06:40 PM
DieHard
07-14-2017 09:19 AM
Bishop
08-15-2015 11:31 AM
scottmb23
08-17-2013 08:23 PM
Quick Reply: AC odor/ AC drain
