Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
RR Evoque 2013 New Brake installation
Old 10-27-2016, 01:04 PM
AustinTX's Avatar
3rd Gear
Default RR Evoque 2013 New Brake installation
I need to install new brakes for the front and rear on my 2013 Evoque. Is there something special I need to do to release them and install properly?
Thank you!
Old 11-28-2016, 03:48 PM
djkronik57's Avatar
Yes, there is a specific procedure of button pressing/pedal pushing to get the rear electric parking brake to disengage into "maintenance mode." Otherwise, you won't be able to change the rear brakes. Can be found with a quick search, but takes a few tries to get right. You'll hear the electric motor when it works.
You'll also need a pretty complete tool set as the front and back brakes use different hardware (from what I recall, backs require a very large Torx bit which I didn't have and fronts required a very large hex bit I didn't have). A piston retracting press also helps a lot.
All in all, not a bad job as long as you have the right tools and get the EPB procedure right.
jeff.marsh
LR2
02-24-2023 06:55 AM
leshill
Range Rover Evoque
03-15-2017 01:48 PM
AustinTX
10-27-2016 01:04 PM
Dinh Quoc Trung
Range Rover Evoque
06-22-2016 12:59 AM
dukefan
05-28-2015 09:13 AM
Quick Reply: RR Evoque 2013 New Brake installation
