If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
So it is a pretty big difference? I like the look of the whiter lights.
__________________
Cam
2000 Disco II "Ruby" with 117k miles
Upgrades: General Grabber A/t2 (255/60r18), A-frame brush bar with Aux lights, Safari roof rack with rear aux. light, rear ladder, CB Radio/antenna. CDL Upgrade Complete!
I have not put one in the front yet. It will be too bright when driving but I hate the way it looks without all three being the same. They do dim but since it takes less power to run the led lights the bulb up front goes out before the back two.
__________________ -Ed
99 DII, TF +2" HD & steering damper, TreadWright 265/75/16, ARB front, BritPart rear, Warn m8000 with synth, Columbia Overland gate panel & dual battery tray, Safari snorkel, RoverBones diff guards, RockWare sliders, DieHard Plat Deep Cycle, Chalkboard Headliner, CB, Wilderness Rack, 6 hella 700 ff's w 100w bulbs, 2 hella work lights
93 RRC TF track rod, tie rod & steering damper, TRW rims
