Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > ROAMING WITH FRIENDS
Register Forgot Password?
Old 04-18-2010, 05:38 PM
Philip Lawrence
Send a message via Skype™ to Spike555
Default Who wants to lay odds?
Ok, who wants to lay odds on my truck with 189,342.7 miles on the clock making a 2500 mile trip at the end of the week trouble free?
Today I changed the oil (was not actually due until 190k)and checked all the vitals.
Cleaned the oil separator and t-body, both were already pretty clean.
Checked the air filter and greased all four u-joints and both slip joints.
Cleared the clogged rear axle breather.
Later this week I am going to lube all the locks and hinges and remove the spare tire and check the tire pressure in all five tires.
Then Friday night we leave and will be back on Monday.
So...a 1997 DI with 189k, will she make it?
__________________
www.marshill.org
Walk by faith not sight.
The "Storm Trooper", 1997 Discovery with 214,000 miles.
www.20liters.org
Old 04-18-2010, 07:05 PM
Long Haul's Avatar
Senior Member
It'll do it spike
__________________
-Brian-
-HIS-99 DI SD Slightly Modified
-HERS-96 DI SE7 5 speed Its got a lift too
Talk is cheap,Beer is good,and people are crazy
www.nelrc.com
Old 04-18-2010, 08:36 PM
XCELLER8's Avatar
Senior Member
Smile
I'm betting you'll make it with no problems, btw........where are you headed ? and have fun!
__________________
98 DI, 203,000 MI...head gaskets, new starter, replaced cracked ex manifold, replaced ex system tires...cooper "discoverers" , 60,000mi service done every year,cheap champion plugs, remanned steering box, back door hinges, rear window lift ecu bypass, several other repairs...most all work done myself
Old 04-19-2010, 07:05 AM
Antmen's Avatar
Senior Member
And here I am worrying about taking my 04 DII w/ 92K to Sesame Place from North Jersey this Summer.
Anyway - how about tires? Does that count? I got my money on tires. With everything else you're doing/have done, don't overlook your tire pressure.
-Anthony
__________________
04 White Disco SE w/ 92K miles
  • Issues: none
  • To-do: get new General or Nitto tires (now has Nexen Roadian HPs), replace crankshaft sensor, clean/replace throttle body heater gasket
  • Completed: air filter, oil/filter change, rebuilt front driveshaft, replaced both upstream O2 sensors (Service Engine Soon light off and no codes), 3 amigos gone after rotors lost oxidation from storage, replaced F/R window regulator, Magnecor 8mm, Bosch Platinum +4's
Old 04-19-2010, 12:18 PM
Philip Lawrence
Nope have not checked tire PSI yet, thats on the "to do" list for this week as well as lube the door locks and hinges.
A friend and I are going to a concert in Ft. Worth and then a open air festival in Ok. City OK and then back home.
__________________
www.marshill.org
www.20liters.org
Old 04-19-2010, 12:26 PM
Senior Member
Make sure you fill up on FAITH before you leave! I bet your good to go!
__________________
2003 DISCO SE7 69000 miles
Tuned @ 62000, rebuilt Drive shaft
Mobile1 syn K&N 3001
More to come!
Old 04-19-2010, 01:47 PM
hilltoppersx's Avatar
Senior Member
edtatton
id go broke paying for gas on that trip.... if anything on the truck broke i would have to walk home
__________________
-Ed
99 DII, TF +2" HD & steering damper, TreadWright 265/75/16, ARB front, BritPart rear, Warn m8000 with synth, Columbia Overland gate panel & dual battery tray, Safari snorkel, RoverBones diff guards, RockWare sliders, DieHard Plat Deep Cycle, Chalkboard Headliner, CB, Wilderness Rack, 6 hella 700 ff's w 100w bulbs, 2 hella work lights
93 RRC TF track rod, tie rod & steering damper, TRW rims
Northeast Land Rover Club
www.nelrc.com
Old 04-19-2010, 06:40 PM
Philip Lawrence
Quote:
There is always plenty of that around.
__________________
www.marshill.org
www.20liters.org
Old 04-19-2010, 06:42 PM
Philip Lawrence
Quote:
Gas is going to be around $400 for the whole trip.
Camp site, $10.
Concert tickets were $35.
All that is left is food and drink.
A 12 pack of Mt. Dew and Nutter Butters and I'm good for the ride down.
__________________
www.marshill.org
www.20liters.org
Old 04-19-2010, 09:49 PM
bikingteacher's Avatar
Senior Member
I just did Ft. Lauderdale and back in the mine. I did develop the classic throttle body gasket leak about 300 miles into Florida. I will be fixing it this week.
Mine did great--I even got a tank average of 24 on the good Indiana gas (94 octane). Most of the time I was rolling 16-18.
__________________
Roverless.
Tags
amigos, discovery, land, pressure, rover, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
