X2. It can be done but you can get a lot better for your money and time.
__________________
97 Discovery SD-7 187K miles 2nd emissions reset.
Custom Saudi grill, Magnaflow cats, Magnacor wires with Bosch+4 plugs, RP oil in everything, New bushings, Bilstein shocks, Brembo rear cross drilled, EBC front dimpled and slotted, Pretty much stock, but every part on her touched. Oh- and a Camel Trophy D2 as my icon on my GPS..
Good Oil
2000 SE waiting in a barn for a 4.6 to come along
1996 SE ready for tranny and the roof cut off!
the 5.3 has about 80 more lbs torque than a rover 4.0. That would make the tranny the weak link considering that the diffs should already be upgraded if you have tires and go off road. That leads you to two choices:
1. put about 40 more lbs torque to the stock tranny than you should and hope it holds using an adapter plate
2. adapt a chevy tranny to the stock transfer which I believe there is a write up somewhere on d-90.
#2 would put you half way to having a nice diesel in dollars
#1 could be done for under 3 grand.
Just my opinion
__________________
2003 HSE Disco
1994 arles blue Defender 90
Just my opinion
So it has as much torque as the 4.6?
__________________
2003 Discovery II CDL equipped
285/75 r16 Destination M/Ts
Ok that video proves absolutely nothing, anybody can walk around a Disco with a video camera and dub in any exhaust sound that you want.
Now had he opened the hood and ontop of the engine it said LS1 or some such to prove that it was not a LR engine then I would be alittle more inclined to believe it.
But as that video stands right now...it means nothing.
And I still dont know why you would want a Chevy engine in your Rover, makes no sense at all.
If it ain't leakin' it must be empty!
Yes, one man can change the world.
Walk by faith not sight.
I would rather you hate me for who I am than love me for who I am not.
The "Storm Trooper", 1997 Discovery with 187,000 miles.
how many goats do you have climbing on the dead cars in your yard ...motor aint the problem its the driver if used as intended it wont be outperformed by a small block chevy in the rocks and hills that is
I know that my tahoe weighs as much as my 03 disco and will run circles around it and get a lot better mileage. I still have no complaints on the power from the 4.6. Just responding to the post. The 3.9 and 4.0 motors (same motor) were lacking.
__________________
2003 HSE Disco
There is no way a Tahoe gets better MPG than a Disco, any Disco.
A Tahoe gets what, 16 MPG expressway?
16 in town and almost twenty on road trips. 150k now. doesn't burn a drop and no leaks. No dash lights either. I'm not changing my disco, but the idea of someone combining things is not bad. Keep in mind that the tahoe is not in 4x4 at all times.
__________________
2003 HSE Disco
