LandRover Forums - Photo Galleries - Create an Account
Go Back   Land Rover Forums - Land Rover Enthusiast Forum > General Land Rover Forums > General Tech Help
Old 10-17-2009, 04:58 PM
agentbuilder's Avatar
agentbuilder agentbuilder is offline
Junior Member
Default Need help with electrical
None of the widows works, dash lights come on but the speedometer the gas gauge or the overheating gauge works, The moon/sun roof wont open, We replaced the fuse box under the hood, as that is what the seller told me the problem was. However that only fixed the headlights and tail lights, It did turn on the AC and heater too. Any other suggestions would be greatfull
Jim
Old 10-17-2009, 05:53 PM
gcredlon gcredlon is offline
Member
first off let me ask what model and year it is, because that really gives a clue as to what the general problem could be. I.e. if its a disco I, i'd say start under the glove compartment and check the relays and the stuff near the spider, because under there controls all that stuff your talking about, rear windows front windows etc.. There is plenty of info here for other places for different vehicles that electrical stuff can go wrong.
Old 10-17-2009, 08:37 PM
Junior Member
Default sorry
it is a range rover 98 se, I noticed the dash lights come on , but the speedometer and rps, fuel gauge and heating gauge do not work, not sure what to think, the AC comes on after about 10 minutes of driving and the windows and sun roof still doesnt work.
Old 10-18-2009, 03:32 AM
Member
There are multiple fuse Banks so i'd check all of them, i.e. not just the one under your hood, also one under your dash. Sounds like a bad harness or ground somewhere. Grab a schematic and see where all of those wires meet. Should be in the engine block or under the dash. There should be a schematic somewhere in the back of your Manual.
Old 10-18-2009, 03:34 AM
Member
Also get a good test light with a long leed it's your best freind at times iike these, because you can see where powers flowing too etc.
Old 10-18-2009, 01:24 PM
Junior Member
Default Ok, I will try that
I found 1 frayed wire that leads to the ignition switch, not sure if that is it, but I will fix it and see what happens. I checked all fuses and they are fine
__________________
CEO Agent Builder Insurance Services
www.agentbuilderinc.com
www.insuranceappointmentsetting.com
1998 Range Rover SE with a new BECM!
Old 10-18-2009, 09:59 PM
Junior Member
Default hmmm
Well the frayed wire wasnt it.
__________________
Old 10-19-2009, 06:27 PM
Junior Member
and the alternator and battery have been tested all works fine, However the problem is still around. getting a electric diagnostic tomorrow, will let you know what we find out
__________________
Old 10-20-2009, 03:56 PM
Junior Member
Ok, they tell us it's the BCM where can I get a cheap one?
__________________
Old 10-24-2009, 01:04 AM
fusshasli fusshasli is offline
Junior Member
I accept: the alternator and battery have been tested all works fine.
Tags
1998, battery, becm, electrical, forums, fuses, immo, land, problem, range, rover, speedometer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
Land Rover Accessories
- Bicycle Racks
- Roof Rack, Kayak Racks
- Headrest Monitor
- Brake Controller
- Thule Bike Racks
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
