Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Brand Reviews > Suspension sponsored by Arnott Inc.
Register Forgot Password?
Old 10-27-2008, 03:29 PM
Junior Member
Default '96 4.0 Suspension conversion?
Ready to switch from factory lift susupension and just go with reqular shocks/struts. Do I need to buy a kit for this or is it as simple as going to a suspension shop and have the current susupension removed and shocks/struts installed. Thanks.
Old 12-08-2008, 09:02 AM
Junior Member
Default RE: '96 4.0 Suspension conversion?
Does anyone know how much this will cost?
Old 12-24-2008, 12:14 AM
Senior Member
You'll probably need to order the shocks/struts and then take it to a mechanic to have them installed. It just depends on if you mechanic has the correct shocks/struts for your vehicle. If you're talking about the air suspension then no it's not that simple.
Shocks can be fairly cheap to pretty expensive depending on what you want. Some work better and last significantly longer than others... they can be a pretty penny. I'd check out Atlantic British or British Pacific for some options.
Regards
__________________
2008 Maserati GranTurismo GT in Blu with Bordeaux Interior
2007 Range Rover Autobiography in Giverny Green with Navy/Parchment Lined Oak Interior
2000 Range Rover HSE in Kent Green with Lightstone Birds-eye Maple Interior
Old 01-30-2009, 08:29 PM
Fivespddisco's Avatar
Senior Member
Quote:
ORIGINAL: oliveoil
You need to change your spring perches. the air bag bolt onto the axel and the springs will need to sit on the plate bolted to the axel in the same place. If you need the kit or more advice shot me an email
Justin@Lucky8LLc.com
__________________
For expedition tested Rover gear Check out WWW.Lucky8LLc.com 716-898-8153
Tags
96, conversion, forum, range, rover, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
