Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Brand Reviews > Suspension sponsored by Arnott Inc.
Register Forgot Password?
Old 12-10-2008, 10:56 PM
Junior Member
Default '96 suspension failure
just bought a 96range rover with 53k miles. Had it for2 weeks andthe air suspension started malfunctioning. It would not inflate on initial startup, but would work fineafter beingdriven a mile or so. This happened a couple of times andnow the air bags will not inflate at all. the pump runs, but nothing happens. I can't finda leak in the bags or in any of the lines. Any thoughts????
Jeremy
Old 12-24-2008, 12:10 AM
Senior Member
Default RE: '96 suspension failure
Do the bags look worn? You may not be able to locate the leak if the bag is folding over it (which it did on mine). Don't use the vehicle as you're putting wear and tear on the pump. You should have stopped driving it immediately when it would not inflate on initial startup... that's the warning sign you have a problem that needs to be fixed immediately to prevent other problems.
Regards
__________________
2008 Maserati GranTurismo GT in Blu with Bordeaux Interior
2007 Range Rover Autobiography in Giverny Green with Navy/Parchment Lined Oak Interior
2000 Range Rover HSE in Kent Green with Lightstone Birds-eye Maple Interior
Tags
96, bags, fault, hse, inflate, land, rover, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
