Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Brand Reviews > Suspension sponsored by Arnott Inc.
Register Forgot Password?
Old 12-03-2007, 10:53 AM
Junior Member
Default Locking the suspension
How do you lock the suspension for when you want to change a tire or change the brakes or something like that?
Old 12-03-2007, 11:10 AM
ajh ajh is offline
Senior Member
Default RE: Locking the suspension
You don't. You can probably block it to prevent it from lowering but unless you disturb one of the height sensors (Disco) it won't lower.. usually. There is a company who makes a manual way to inflate the suspension that would work I guess.
__________________
1992 Defender 110 200TDI CSW, Discovery II
Raptor Engineering Dash Components for Defender, Discovery, RRC, importer for NA.
Old 12-03-2007, 11:24 AM
Junior Member
so how do you change your tire without risking messing up the suspension?
Old 12-03-2007, 12:50 PM
llesra's Avatar
Senior Member
Send a message via AIM to llesra
in a p38 you leave the tailgate open to lock the suspension. lift the truck under the axle to change a tire/brakes
__________________
Arsell
97 Discovery 4" lift, 35s, etc
99 Range Rover 4.6 HSE
Old 12-03-2007, 01:59 PM
Junior Member
Does that almost work when I bring it a mechanic and they want to put it on a lift machine?
Old 12-03-2007, 03:28 PM
Junior Member
in the lr3 . i remember just putting it in offroad height .then holding the switch untill you hear a chime...i believe a light will come on in the dash.
after fighting the air suspension for 20 min, i had to do what no man should have to do to change a tire...USE THE MANUAL !
Old 12-03-2007, 04:43 PM
llesra's Avatar
Senior Member
tell them to use floor jacks and not the lift. locking the suspension only works when the vehicle is on the ground.
__________________
Arsell
Old 01-04-2008, 10:03 AM
Send a message via Skype™ to Disco Mike
If you are worried about picking up a D2 with SLS, don't worry.
I lift mine all the time, sometimes the suspension will settle sometimes not, but as soon as you put it back on the ground it will reair back up.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
To Download the RAVE Manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Need Parts?
paulgrant@mac.com, or 203-770-1699
willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
Old 01-14-2009, 09:47 PM
Member
And what about a LR3, how do i change the tires ,etc ?
__________________
t0nz
Tags
03, 2006, air, axles, change, front, land, lift, lifted, lock, lower, lr3, p38, range, rover, suspension, tire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
