If this is your first visit, be sure to check out the FAQ by clicking the link above.
You may have to register before you can post: click the register link above to proceed.
To start viewing messages, select the forum that you want to visit from the selection below.
i have a three inch lift on my 92 range rover classic. i am interested in buying some larger tire to go with my lift. i would like to run either a 33/12.50-r16 or a 35/12.50-r16. or a 315/75-r16 wich measuers out to 34.6 inches by 12.2 inches.
thanks for any help. i searched abit on tire sizes but havent been able to make a confident choice yet. an i mainly use the rover for trail use only.
you should put this in the RR section - probably get a better response.
__________________
'03 Disco2 SE 4.6L - 112K
OME Lift 751F/763R and 60024F/60025R shocks
275/65/R18E Goodyear DuraTrac's
Safety Devices high-rack, 5 Hella's (LR switches), Farmtec flooring, LR ladder, rear light guards, LR brush guard, limb risers and a Vigg blackout
8mm Magnecore, Denso plugs, and Tom Woods HD shaft
Every seal/gasket replaced and TONS of Misc replacement parts here and there...
Coming Soon:
'04 CDL, bumper/winch, sliders, radius arms, HiLift, on-board air, and a CB.
Probably with a lot of triming and wheel spacers.
Which axles do you have, you'll need HD axles and lockers cause the spiders from a stock diff won't take the stress.
__________________
Mike
Retired service manager. Member of the Solihull Society, NCLR club, SCLR and Santa Barbara 4 Wheelers.
99 D2, 3" lift, CDL with a Detroit and T.T. lockers, H.D. axles, 4:11 gears, Custom front and rear bumpers, sliders, Warn winch, and 5 HID's.
Need Parts? paulgrant@mac.com, or 203-770-1699 willtillery@roverguy.com, or 434-251-9331
Paul PTSchram 260-804-0458
PM Marty(Drillbit)[url]http://www.landroversonly.com/forums...o=newpm&u=5940
British Parts of Utah, http://www.bputah.com/
Lucky8, http://lucky8llc.com/
i have the stock 24 spline`axles i belive. so that means diffs an axles. that will be a few $.
i think i got talked into a 31.5 inch tire today at the tire center. but first i thought i would ask. can i run a 31 inch tire with out having to do my diffs an axles? i decided any thing over 33 will be a bit excesive for me.
if not i might as well buy the 280/75-r16 inch tires an order the parts you mentiond. wich i wonder if i can budget a t-case into that. time to call toddco. any sugestions? on parts? brands , seller?
