Lag or Transmission?
Folks,
My 2020 110S P300's rear diff was recently replaced (~1,000 miles) under warranty. This solved the growing problem of clunking under low speeds, especially at turns and initial acceleration.
I'm noticing something odd now: when driving around town, the downshift and lag seem a little more abrupt/aggressive than I recall previously. I'm also finding it occasionally seems to slightly stall/stumble when going about 20-25 MPH, an odd sensation of hunting for the gear while stuttering like it's running out of fuel.
I didn't have my car for a month during the repair, and while I was fixated on the diff issue maybe this was happening unbeknownst to be but I think it's unlikely. So, I'm taking it back to get looked at (warranty has 3 more months so being very aggressive about having things taken care of) but welcome any thoughts or similar experiences.
Did they reprogram the transmission? Sometimes that happens, and the car will have to relearn your driving style. Also, the rear diff clunk is normal and isn't anything to be concerned about. I'm still shocked that they replaced it under warranty. But hey, I wouldn't be complaining about a new rear diff!
Mine started as a noticible clunk and then grew in noise and vibration -- my kids could sit in the back and say they felt it. It's not normal, and others on this forum have experienced the same issue with bad outcomes. Mine was replaced after the dealer did two fluid flushes per JLR's guidelines before getting approval to replace the unit which is ~$5K alone. There's a tech bulletin on this issue.
The rear differential clunk is normal? I would love for this to be true, but my e-lock rear differential does this and all the threads on here lead me to believe it will end up in a differential replacement. Perhaps the OP does not have the e-lock spec’ed and the situation if different.
