Low Profile Ditch Light Install
Just finished installing low profile ditch lights on my '23 D90 P400. I wanted something low down, unobtrusive, and didn't want to spend a ton on custom brackets. I used some Nilight clamp on hood brackets ($13) -- I didn't use the top section. I designed and 3D printed my own top section brackets to keep it as low profile as possible. Total height with lights is just under 4 inches installed. Wiring is via Trigger 4 Plus mounted near the fusebox. No need to run switch wires through the firewall (it has a wireless control). The light pods are Jammy J-14210-S and they are great fill in for ditch/side lights. Total cost for lights brackets: less than $120. The Trigger 4 setup is spendy but worth not having to send anything through the firewall. I have seen a lot of questions about the switched fuse location for lighting accessories. Use engine bay fuse # B9 which only comes on with ignition. Hope you like it and hope this helps guide others.
https://cimg7.ibsrv.net/gimg/landrov...f9577cecb.jpeg https://cimg9.ibsrv.net/gimg/landrov...4dcae821e.jpeg https://cimg4.ibsrv.net/gimg/landrov...d7c3115b1.jpeg https://cimg1.ibsrv.net/gimg/landrov...94857a2e9.jpeg https://cimg2.ibsrv.net/gimg/landrov...ec3fd306d7.png https://cimg8.ibsrv.net/gimg/landrov...db72846535.png Here are some product links: Lights: https://jammyinc.com/products/j-14210-s/ Lower Brackets: Trigger 4 Plus: DM me if you need the 3D art to print your own brackets (Must use ABS Plastic) or if you want more pics of the install. |
| All times are GMT -5. The time now is 01:20 AM. |
