New 2020 Defender Lift Kit by Johnson Rods
#161
Defender Lift by Johnson Rods
Do you encounter any rubbing at full turn?
May go with a more aggressive tread. Toyo RTs or General Grabbers or BF Goodrich HD All Terrain Thoughts?
#164
#165
275-60-20 Nokian At tires with the 1.5 inch Johnson Rod lift.
Check out our Wheel options for the Defender
shown in off road mode
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
#166
This may be a dumb question but for the 1.5"inch lift, it is 1.5"inches taller in all 3 settings (access, normal, off road)? or does it sit normally in access mode then lift higher in normal and off road, or just off road? Thanks, I'd like to pull the trigger on a set but it is just a burning question that's been on my m mind.
#167
FareWarning (11-17-2023)
#168
285-45-22 MT tire with Johnson Rod 1.5 inch lift.
Check out our wheel and lift options for your Defender:
Johnson Rods
Johnson Rods
__________________
#169
How do these lift rods impact "extended mode" that can be engaged if the vehicle becomes high-centered? If required can the vehicle still be raised higher when in extended mode?
Also, I'm hoping to fit LT275/70/18 on my Kimberleys with a +29 offset. (33.2" diameter tire) Will any Johnson Rod lift height avoid a rub at normal ride height?
#170
The rods replace the original height sensor rods and adjust the sensor's position which signals the system to raise the suspension by an additional 1.5 inches.
The bags will not get overinflated and the compressor works the same by holding pressure as it would at any height.
We only go 1.5 inches because that provides the best overall ride quality based on customer feedback in both on and off road modes.
