A Pillar Flapping / Crackling noise at speed
#181
I think the NEW A pillar fix has come down to the capability of the dealer to install it. RedAustin found a dealer who could make it adhere -- I am not yet there with the same, new fix attempted twice and failed.
My next need is to change the transmission fluid, as I am towing and am past 30K miles. I hesitate to have any dealer where I am presently located (Massachusetts) attempt it, even after I walk them through the directions (I am afraid they will mix up the 3.0L versus 2.0L steps).
I think I will take it down south and have LR Asheville do the work?
Enjoy !!
Enjoy !!
GrouseK9 (01-30-2023)
#182
The JLR dealer in Massachusetts today finished their final attempt at fixing my driver's side A pillar -- 3.5 months after their last attempt. It is their final attempt -- I will fix it myself if it comes off again.
There are reportedly completely new part numbers that are being utilized, except for the lower trim piece (which I believe has been manually modified for it to fit).
On a better note, the outsized plastic trim pieces on the rear doors were replaced under warranty and the doors open easier now.
Enjoy !
November 30th 2022 parts list used under warranty.
I hope it works this time.
Enjoy !
#183
Has anyone seen the white 110 for sale on Cars & Bids right now? (great defender... ). It is quite amusing to look at the photos at the end of the listing, the poor owner took it into a LR dealer and complained / commented on the pillars rattling around at least 3-4 times. Every time they said "cannot duplicate customer complaint" until the last time, in which they fixed it. And this was in 2022 (but it started in 2020/2021 I believe...). Still a bit shocked that LR dealers don't just replace these parts the first time someone says "it's making noise"
EasternShoreDefender (12-01-2022)
#185
A Pillar snaps off on Florida Turnpike
Happy to see this forum topic. I have had the A Pillar replaced once already. Now the rattling was louder and on just flipped off on the road and I had to stall and tear it off so I could keep driving.
Now I’ll pass this along to dealership, as there has been no info from them about this being a known issue.
A-Pillar decides to snap off on the Florida turnpike. Go around number two for new Pillars (on back order) and now I have some info from this group to share with dealer. Thanks for the info.
#186
This guy is on the money. I took mine to the Charleston Dealer after noticing the issue the day after I bought the vehicle, preowned from their dealership. After a service for this issue, the windshield sand/rain noise kept happening. I live over an hour from the dealership so I thought I would try a remedy myself. After reading this post and a following post, I got some foam stripping from Wal-mart. I was unable to get 1/8 inch high density foam, but I got some 3/8 inch thick foam stripping from WalMart that is meant for home window seals. I did as another poster said and left the A-Pillar alone and tucked the foam tape underneath the weather stripping (between the weather stripping and the window.). I took off on a drive over 60 mph and NO MORE window rain tapping noises!!!!
#187
gurka01 (01-29-2023)
#189
#190
Much appreciated.
