Possible new owner -- accessory wind noise questions?
Hey
Post #2 and full of the dumb questions -- don't you love new posters? I searched and did a bit of Google and didn't find a good answer.
Current 2013 Evoque owner, and long time (original) Defender fan. The new one has tickled my fancy, so I'm poking at some of the options for an MY2021 Defender.
I love the 'look' the ladder and the external gear locker bring, though I don't think I'd mount the expedition rack. Couple of questions on those:
1) Folks with the gear locker -- is it actually useful? It's not cheap, and I'm not sure if it's a factory accessory on the 2021 or dealer mounted
2) For the ladder and the locker, how much wind noise do they add?
Thanks!
Thanks!
For 2021, I'm told that the accessory packs are all dealer-installed items, unfortunately.
Regarding noise, it would be most useful to hear from someone who didn't have the lunch box or the ladder for a while, then added them and can provide a comparison...or, I guess, maybe someone with two Defenders?
Nate
Nate
I use the external gear carrier for my recovery gear. It holds my tow straps, D Shackles, Gloves, and ****** Block perfectly. This gives me easy access when I have need of the winch. I previously used a recovery duffle that would at times get buried in an inconvenient spot when needed. I also have the ladder, and have used it to load the roof. The only wind noise seems to come from the expedition rack, extremely noticeable if the sunroof is opened even the least bit. Possibly for that reason, I've heard no other wind noise
Nate
Nate
I have the expedition roof rack and the ladder and find that there is quite a bit of noise. I can't compare to not having them though but... The noise increases quite a lot at highway speeds. Compared to my previous car, Ford Flex, the defender is a lot more noisy at around 100kmh but quieter at around 50kph. I suspect that the roof rack adds way more noise then the ladder. But I just love the look, and it does come in handy.
I agree . The rack is the main noise generator, not so much the ladder. i don't have the lunchbox. I had my defender for a month before the rack and ladder were installed. At highway speeds, there is a noticeable difference with it on vs. off. At lower speeds, there isn't that much of a difference.
