-   2020 Defender (https://landroverforums.com/forum/2020-defender-60/)
-   -   Size up or down for winter tires?? (https://landroverforums.com/forum/2020-defender-60/size-up-down-winter-tires-108515/)
BlueSteelDefender Oct 12, 2021 01:45 PM
Originally Posted by Craig_RRS2013 (Post 795689)
In the same boat as you, although I am worse off in the 255/65/19 OEM wheels and tires. The Land Rover user guide suggests the Continental TS 850 P SUVs in my wheel size, however, such a tire does not seem to exist state side. For 20" OEM wheels, the same guide recommends the Pirelli Scorpion in the 255/60/20, however, it also recommends the Nokian Hakkapelliitta R3 SUV in 275/55/20. As long as you have OEM wheels, should be good to go with 275/55/20. This is what I am likely to do after securing some 20" wheels. Good luck!
I like how the user guide mentions the 275/55/20 Nokian Hakka. Thanks for passing this along.
Originally Posted by gts944 (Post 795721)
It depends. Narrow will work better in deep snow, cutting through the snow to where there is traction. Wider will work better on ice. I just ordered 275 Conti Viking Contact 7s for Colorado ski trips. Couldn't find a good source for Hakas locally, though I've run Nokians with good results in the past.
Great info. GTS944 the distinction between the strengths of a narrow winter tire vs a wider one makes a lot of sense. It makes it clear that I want the 275 width. I'm leaning towards the Nokians but a close second are the Michelin X-Ice and maybe the Blizzak.
