Wheel spacers for the V8 defender and standard arch
sorry can’t help you in size but all defender wheels use a very similar offset wheel.
there are some older threads that will give you size. i believe it’s in the 25-30mm space to push wheels right to the fenders
just purchase a high quality set such as H&R and you should be fine. i have ran H&R on all my other cars and no issues
Did you ever end up getting any spacers? I dont have a v8, but I do have a 130 x-dynamic with the 22"... I'd like to flush the wheels/tires out a bit more before I go aftermarket some day.
All the spacer threads are on wheel sizes less than 22's.
Some mention having to shave the studs down which I will not do. I'd rather go 25mm but if 30mm allows for no shaving, I'll go that route.
