Which one spray is best for the bed liner
For the price, durability, function and application method, I am searching bedliner spray .I HAVE SEEN MANY BRAND NAME LIKE QWIKLINER ,LINE-X,ETC.WHICH ONE BETTER
show me the picture after the spraying the bedliner.
Any input will be greatly appreciated.
spray on bedliner
I have qwikliner in three truck beds and feel that it is a better product than others. It seems to be tougher. However, the key to getting a good spray-on bedliner is the installer. If they cut corners, or don't know what they are doing, you can get a lousy job from either brand. Look at some trucks the installer has done before you let him do one for you. Look for clean edges, a good thick even coating, even texture, and make sure they take out any and all bolts, nuts or other removable parts before they spray the Qwikliner on.(Like bolts and cover plates that access tailgate latch linkages) If they have sprayed over this hardware it is a sign that they are doing a quick, cheapie job, AND, you will never get it apart if you need to. A friend of mine is in the business and pointed out to me how to spot these signs of a cheap spray job
spray on bedliner
I bought my truck and immediately had a QWIK Liner put in. Well, that lining paid for itself after just one trip.
After work I set my toolbox at the edge of the bed and drove home - several miles of twists, turns, bumps and hills. When I went to unload, I saw I'd left the tailgate down. I was sure my tools were gone. Instead, they were right where I left them - as if they were glued down. I've bragged how tough and good looking my QWIK Liner is
huh? Thought of this is only 1 person answering his/her question.
@topic
Ever use a Line-X. I using it right now and it works great.
_____________
If you ain't first your last!
mitsubishi parts
@topic
_____________
mitsubishi parts
