-   Audio/Visual Electronics (https://landroverforums.com/forum/audio-visual-electronics-10/)
-   -   D1 Antenna options (https://landroverforums.com/forum/audio-visual-electronics-10/d1-antenna-options-70166/)
fishEH Nov 5, 2014 02:23 PM
D1 Antenna options
Looking for antenna options for my '95 D1.
Will the rear side glass from a '98 with the built in antenna work in a '95?
I know the glass itself will fit, but can I make the antennas work?
I like the clean look of not having the antenna on the fender and the '98 glass is tinted already. :)
ArmyRover Nov 5, 2014 07:31 PM
I thought you drove around listening to the voices in your head :D
As long as you pull the antenna signal amp and associated wiring you should be able to make it work.
fishEH Nov 7, 2014 08:44 AM
They're too loud, need to drown them out with the radio! :D
