Factory alpine Deck?
I am installing a Clarion touchscreen in my 2002 disco. I used an aftermarket wiring harness, but it only used two of the three Rover plugs. Now I have no sound, but the deck comes on. What am I doing wrond and what can I do to fix it, Any help would be appreciated, thanks
RE: Factory alpine Deck?
Hi,
You probably have the premium sound system and the third plug will be the line level audio feed to the amp under the LHF seat (drivers?). You will need an adapter harness or make one up. Thta would be my thoughts anyhoo. Oliver |
So thats where they hide that darn amp!! If i determine what wires power the amp, shouldn't I be able to to run the remote wire from the deck to both positives at that plug, or am I going to need to run them all the way to the amp?? Thanks Oliver for the info, much appreciated
http://www.autotoys.com/x/product.php?productid=2676
You need this and four rca's |
