head unit
is there a wireing harness addapter i can buy to put an aftermarket head unit in my 02 disco
metra part number 70-1786
thanks alot ill give it a try
it makes life a thousand times easier. took me five seconds to wire my new radio. (+- a few mins for crimping)
Dont mean to hi-jack but same question for a 99 range? Also where can I get it from. Thanks
should be the same harness, if you buy things online either google 70-1786 or ebay it. otherwise crutchfield or your local car audio shop (go to a private shop and not a best buy type store) if they don't have it just give them the part number and they can order it for you. by the way that is a metra part number, and there are other harness's for these trucks so use that number not just the truck info.
Hook the head unit up no problem. Now where's the antenna wire at lol..do you the part # for that. Thanks
any car audio shop, ask for a non amplified European antenna adapter. metra lists it as a VW adapter 40-VW12 there are 2 you will use the "main" one.
